 Au secours sur T10 Futaba
Christophe de Pau
Nombre de messages : 140
MessageSujet: Au secours sur T10 Futaba   13.01.09 22:34
Bonsoir à tous
C'est les galettes des rois avec sa collection de féves mais sur ce coup là, la couronne du roi ... ...
elle est pour moi.
En programant bêtement 2 phases de vol sur le même inter, je me retrouve avec l alarme mixage allumé et la radio ne boute plus .
Il faut couper le mix mais ce faisant, on allume l'autre .......
Donc radio bloqué.
Y a t'il un moyen de faire un reset directement ?? La formule magique ne semble pas dans le manuel... du moins pas celle que je voudrais lire .....
Grande année 2009, j'vous l dis moi ....
A++
Christophe de Pau
MessageSujet: Re: Au secours sur T10 Futaba   13.01.09 22:44
Les secours sont arrivés et c est tant mieux . cheers cheers cheers
Autant mettre la réponse:
When I turn on my radio, I get a warning which says (throttle cut, idle down, snap roll, airbrake, butterfly, inverted, throttle hold, or idle up). I've tried moving every switch on the radio, and I can change the error but not get rid of it. I cannot operate my radio. What do I do?
The 10C has a safety feature which will not allow you to attempt to start your model in any of these 'non-base' set ups for safety reasons. Unfortunately, from what you describe, you have accidentally programmed two or more of these features to the same switch, so that no matter what position that switch is in, one of these mixers is active and so you cannot operate the radio. This is a programming error that is a very important one to avoid for the obvious reason that it makes your radio inoperable and if it did not make your radio inoperable it would make your model potentially unsafe to operate.
The 10C includes an override to get around this programming error. Simply turn the transmitter On and then press down lightly on the Toggle cursor. Then immediately access the programming and fix the error.
Bonne nuit
Thierry Cutivet
Nombre de messages : 798
MessageSujet: Re: Au secours sur T10 Futaba   14.01.09 5:05
Merci Christophe, ca peut servir..
MessageSujet: Re: Au secours sur T10 Futaba   14.01.09 7:27
» Au secours sur T10 Futaba
» émission pour radio futaba 6 EXP 2,4GHZ
» Futé Futa .... Futaba
» Au secours !!!! Gros soucis avec mon 40D...
» Médaille de la SSBM : Secours aux blessés militaires 1864-66
