 Vends 4 servos Blue Bird BMS-207WV
prondel
prondel
Nombre de messages : 536
Vends 4 servos  Blue Bird BMS-207WV Empty
MessageSujet: Vends 4 servos Blue Bird BMS-207WV   Vends 4 servos  Blue Bird BMS-207WV Icon_minitimeMar 30 Juil 2019 - 9:16
Vends 4 servos Blue Bird BMS 207 WV absolument neufs.
Idéals pour une installation dans une F5J par exemple, y compris aux volets.
Prix du lot: 70 Euros (au lieu de 104€)
(Envoi possible, port en sus)
Me contacter en privé.
Vends 4 servos  Blue Bird BMS-207WV Bms20710
Vends 4 servos  Blue Bird BMS-207WV Bms20711
Caratéristiques:
Body dimensions 23.2 mm wide x 12.0 mm thick x 27.5 mm high 0.91" wide x 0.47" thick x 1.08" high
Max dimensions 32.0 mm wide x 12.0 mm thick x 33.0 mm high 1.26" wide x 0.47" thick x 1.30" high
Stall torque (3.7V) 3.3 Kg.cm 46 oz.in
Stall torque (6V) 5.4 Kg.cm 75 oz.in
Stall torque (8.4V) 7.5 Kg.cm 104 oz.in
Weight 17.5 g 0.62 oz
Lead length 16 cm 6.3 in
Operating speed (3.7V) 0.09 sec/60°
Operating speed (6V) 0.07 sec/60°
Operating speed (8.4V) 0.05 sec/60°
Operating voltage 3.5V to 8.4V
Operating temperature 0 to 40 °C
Bearings 2 ball bearings
Gear material Metal alloy
Case material Nylon
Motor type Coreless DC motor
Working frequency 333 Hz
Dead band/resolution 2 µs
Pulse width for ± 60º (L) 900 µs - (0°) 1520 µs- (R) 2100 µs
Digital Yes
Programmable No
Position feedback Potentiometer
Supplied accessories 2 plastic output arms, 1 arm retaining screw, 4 mounting screws, Blue Bird sticker
» Retour avis servo blue bird Hobbyking
» vends pontiac fire bird
» accus dans F3K
» Mon monster electrique : BOMBMAXX
» Blue Bird - Eco-village ?
