 Le Cyril - evolution du Ceres ?
Aller à la page : 1, 2, 3, 4, 5, 6, 7  Suivant
Yannick Krust
Nombre de messages: 414
MessageSujet: Le Cyril - evolution du Ceres ?   Mar 14 Juil - 11:39
"Finally here is info about new model:
Actual we start production of new model Cyril. We tested several prototypes in conjuction with D.Duchesne and A.Böhlen more than half of season. We are very content with results of tests and we are sure that can offer you really good F3B model.
The airfoil is great work of Dirk Pflug and combines qualities both previous models (Ceres and Ceres Lift). The area is little smaller (58dm2), this more matches the taktic of modern F3B competitions. The wingspan is 3m, chord 235mm. The construction of model, specially fusellage, took a step forward. We saved some weight - total flight weight is around 2000g. The fuselage has slip-over nose cone and is automatically friendly to 2,4Ghz. The price of model is higher due to technical difficulty fuselage production and application RDS systems for ailerons and flaps. Same as model Ceres or Ceres Lift is possible order it with assembled servos or in personal colour design.
The price of F3B verzin is 1470euro.
F3F verzion has firmer fuselage and harder surface of wing, the weight will be around 2200-2300g. The price of F3F verzion is 1230euro.
Some rumore and photo was here http://www.rcgroups.com/forums/showthread.php?t=1053728. There you can see some photos of A.Böhlen prototype. After WC F3B I will have time for make better presentation of this model.
best regards Jiri Baudis
baudismodel
www.baudismodel.com"
Yannick Krust
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Mar 14 Juil - 11:58
c est issue du Forum F3F
Nombre de messages: 945
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Mar 14 Juil - 12:25
avec remi on a reçu un mail de baudis avec le nom du modele dans la mesure ou j'ai un planeur en commande, et suite a ce genre d'info on avait demandé pour avoir un nouveau modele a la place du lift.
et la premiere reponse avait eté que ce planeiur n'etait qu'en test et pas encore pret a la fabrication.
donc j'ai quand meme commandé un lift pour terniner la saison.
et le cyril est commandé pour Rémi et moi, et ça arrivera quand ça arrivera, on aura peut etre la chance de ne pas devoir attendre trop longtemps
on vous tiens au courant des qu'on en sait un peu plus
Jean-Philippe Krust
Nombre de messages: 454
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Mar 14 Juil - 13:19
J'ai eu l'info de Jiri baudis que le planeur est en vente,
delais environ 8-10semaines, les prix sont ceux indiqués par mon frère plus haut.
il donnera plus d'info après les championnats du monde
Jean-Philippe
jeremy_lagrue
Nombre de messages: 687
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Mar 14 Juil - 18:47
Ce que je trouve bien c'est la soute à ballast dans le fuselage en plus de celle dans les ailes et la clé.
En tout cas Jiri rentabilise ça CNC !
Jérémy Lagrue - 杰瑞米
Nombre de messages: 3148
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Mar 14 Juil - 19:22
Ce que je reproche un peu au Ceres, c'est sa relative fragilité par rapport à sa masse.
Mon Shooter pèse 2120gr en version double carbone. La peau est béton ! Le Cérès Lift pèse a peu prés pareil mais la peau marque très facilement. Niveau rigidité, je préfére le Shooter aussi. Bref, Baudis ne doit pas avoir une résine terrible...
Pour le reste, la finition du Lift était très correcte, le kit bien fournit en accessoire et le prix encore dans les bas tarif pour une des 3 meilleures machines actuelles... jocolor Bref le Cyril devrait faire un carton aussi ... cheers mais je me réserve pour une autre machine .
jerome vadrot
Nombre de messages: 371
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Mar 14 Juil - 19:44
Oui, accro du ceres, j'attends de voir le crossfire 2.
Jean-Philippe Krust
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Mer 15 Juil - 7:28
Dans le cas d'une commande je serais également partant en fin d'année,
a voir, Cyril, Crossfire2, shooter ou dingo....
Jean-Philippe
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Mer 15 Juil - 15:08
N'esperez pas trop sur la commande groupée ! Jusque là on n'a pas négocié même en prenant 7 Ceres... Ah si des déco perso !
Franck CORNU
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Mer 15 Juil - 17:48
Comme cela semble vous plaire, voilà la 2nd réponse à mon mail.
Citation:
Hi Franck,
yes, "Cyril", I hope it isn´t to much crazy name for French people?
thank you for your order. It should be ready during 8-10weeks.
baudismodel
www.baudismodel.com
carlesf3b
Nombre de messages: 65
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Lun 20 Juil - 21:31
premières photos ...
http://picasaweb.google.es/carlesCTNA/Cyril#
Voir le profil de l'utilisateur http://f3bcat.blogspot.com/
Franck CORNU
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Mar 21 Juil - 8:22
Jiri m'a dit que le fuselage était friendly 2.4Ghz de fait.
D'après les photos, la contre ogive serait en carbon, c'est pas glop du tout.
Est ce un proto ?
Dans le doute j'écris à Jiri
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Jeu 23 Juil - 9:10
sur RCGROUPS, les photos du planeur d'Andreas Bolhen montrent un avant en carbone aussi.
Cependant, Carles et Andreas volent en 35MHz si ma mémoire est bonne...
carlesf3b
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Jeu 23 Juil - 10:02
vrai, mais je suis dans le proces de changement à 2,4GHz Arrow
Laurent, vous avez le Shooter avec 2,4 GHz?
l'ogive c'est GFK et l'intérieur c'est CFK ¿?
MessageSujet: Re: Le Cyril - evolution du Ceres ?   Jeu 23 Juil - 10:17
Carles :
Shooter avec fuselage 2,4GHz friendly (il faut le demander, pas plus cher)
Ogive GFK et contre ogive GFK aussi.
Sur le Shooter non friendly, ogive GFK et contre ogive CFK -> j'ai eu des problemes...
Page 1 sur 7Aller à la page : 1, 2, 3, 4, 5, 6, 7  Suivant
» L'évolution des armures de bronze
» [Blu ray] Underworld Evolution (Import US)
» Le Cyril - evolution du Ceres ?
» Cyril F3F
» réglage Cyril
